Location of the udf.h File
Like Tree1Likes
  • 1 Post By nb92
Old   April 2, 2014, 22:24
Default Location of the udf.h File
Svetlana Tkachenko
Светлана is on a distinguished road
Section 5.1.1. of user manual says that "before you compile your source file, the udf.h header file will need to be accessible in your path, or saved locally within your working folder." How do I do that -- make it accessible in my path -- under Linux? Say, I have these files in /somewhere/ansys/v145/fluent/fluent14.5.0/src/udf.h
Светлана is offline   Reply With Quote
Old   April 3, 2014, 02:49
Nick
nb92 is on a distinguished road
In my case the header files are located here: C:\Program Files\ANSYS Inc\v140\fluent\fluent14.0.0\src
I use Windows so i am unsure about Linux. In my case Fluent found the header files without problem, i think by 'path' it means that the file will be in the fluent directory.
I would suggest attempting to compile and if you have issues, move the required header files to your working directory.
Hope this helps
Nick
kardgar likes this.
nb92 is offline   Reply With Quote
Old   June 15, 2018, 06:08
Anomymous
Nishant_Sharma is on a distinguished road
Hi all,
do the folder as you(nb92) have mentioned shows the udf.h file after loading, because in my case it is not showing in that folder, and I could not find the .h file of my source file.
Thank you
Nishant_Sharma is offline   Reply With Quote
Old   June 15, 2018, 06:28
`e`
`e` is on a distinguished road
The udf.h file should be located at .../src/udf/udf.h. Although when writing your UDF, this file is included with:
#include "udf.h"
at the top of your code.
`e` is offline   Reply With Quote
patch error OF v2.2.2 mac hewei OpenFOAM Installation 4 November 30, 2013 16:55
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
