Fluent solver
Old   April 9, 2014, 07:33
Default Fluent solver
Adam
kenzosenzo is on a distinguished road
Guys, i'm having a pressure-based case with k-epsilon turbulent model which to model air flow from ducting throughout a diffuser (in office or class).
how do i decide my solution solver? (simple, simplec, piso?)
and how many iteration do i need?
kenzosenzo is offline   Reply With Quote
Old   April 9, 2014, 10:31
praveen@cfd-online.com's Avatar
Praveen Kumar R
praveen@cfd-online.com is on a distinguished road
SIMPLE, SIMPLEC & PISO are algorithms available in FLUENT to do pressure-velocity coupling. This is to describe how the momentum and continuity equations are coupled.
SIMPLE (default) is most robust
SIMPLEC - Quicker for simple problems
PISO - Quicker for unsteady flows & Stable for highly skewed meshes
If your flow is compressible, then you should consider using COUPLED.
For most of the cases, SIMPLE algorithm works fine.
Happy Learning!!!
Praveen Kumar R
praveen@cfd-online.com is offline   Reply With Quote
Old   April 15, 2014, 05:53
Adam
Originally Posted by praveen@cfd-online.com View Post
Happy Learning!!!
Praveen Kumar R
Thank you Praveen Kumar R for your reply.
and i wonder on the iteration setup,
how do we know or approximate value of iterations to make sure
that the calculation is going to reach the exact value?
from my case above i'm running up to 3000 iterations,
is it consider to be good or not enough? (to approaching exact values)
Buoyancy and the 6DOF solver (FLUENT) i2a FLUENT 16 March 20, 2020 11:20
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
FLUENT Solver i strange BastiL FLUENT 1 July 14, 2008 16:27
Changing from STAR to FLUENT - Solver Troubles BastiL FLUENT 0 February 15, 2008 16:41
help required in using six dof solver in fluent Shah FLUENT 1 February 25, 2006 11:31
