How do I find convergence in ANSYS FLUENT?
Old   April 14, 2014, 21:02
Default How do I find convergence in ANSYS FLUENT?
Robert
Deadpretzel is on a distinguished road
Firstly, I am really new to the whole FLUENT software. I am used to running static structual problems on ANSYS.
I am simulating the sloshing of water inside a tank (similar to the one found on the ansys customer portal). The tank has got and horizontal acceleration on it for a set time then the acceleration is taken off.
I am trying to find convergence on my simulation. The problem is, that I am not sure what values I should be viewing/comparing to identify the point of convergence. I have been told previously that comparing the set of values given for the last time step (x, y and z) should be enough to find convergence but I am not too sure as I have been doing this and they are nowhere near each other
Furthermore, I am also confused about calculating the time step size and the courant number.
It would be much appreciated if I could get some guidance on identifying when or how convergence in met for the simulation.
Thanks
p.s sorry if doesn't make sense, as I am so confused with it all and about to give up.
Deadpretzel is offline   Reply With Quote
convergence, fluent, mesh, sloshing
how to find coating thickness using. fluent.... sumeet kotak FLUENT 9 January 21, 2015 02:54
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 06:10
from gambit to ansys fluent vpdchispas FLUENT 3 March 21, 2011 16:44
FLUENT to ANSYS Temperature Mapping Procedure schreiberc1 FLUENT 0 June 29, 2006 13:50
import Fluent data&case to ANSYS Vlad S FLUENT 0 April 2, 2003 05:49
