-   -   combustion in heated channel (http://www.cfd-online.com/Forums/fluent/133287-combustion-heated-channel.html)
Rana.P April 13, 2014 01:06
Hi guys,
i'm using fluent to study combustion in a heated micro burner.burner is a cylindrical tube with inner diameter of 2mm and the mixture i use is stochiomeric methane-air.
i've tried several mechanisms and mesh densities but i can't give desirable answer.
would anybody help me??
WJXu April 13, 2014 15:38
Originally Posted by Rana.P (Post 485760)
Hi guys,
I am also doing similar things here. In my case, I found that the finite rate/eddy dissipation model burn the fuel very slowly; while the eddy dissipation model would give out much higher temperature and more intensive reactions。。
Could you give out more details about my problem statement? I guess you may need an ignition source.
