Home > Forums > FLUENT
Interface Zones
Old   April 14, 2014, 02:02
Default Interface Zones
Kathy Grün
savoy is on a distinguished road
I simulate wind blowing over an aluminum plate with a thickness of 1.5mm. At the bottom of the plate there are several pipes with a heat transfer fluid. The plate and the pipes are of the same material and connected in one solid. The solar load model heat my plate up. All the Interface Zones are created correctly by FLUENT.
But, if I change the dimensions of the plate (it is not a flat plate, it is a trapezoidal sandwich construction) in some cases with some specific dimensions FLUENT puts all the Interface Zones (the aluminum-air Interface and the aluminumtube-heat transfer fluid Interface in ONE Interface Zone.
Why? Is it because of the small distances between the thin aluminum plate and the inside of the tube??
I hope somebody can help me, thanks a lot in advance.
Savoy
savoy is offline   Reply With Quote
Old   April 14, 2014, 05:45
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
how would u change the dimensions of flat plate?
sharing a picture will be so helpful
CFD-fellow is offline   Reply With Quote
Old   April 14, 2014, 12:07
Kathy Grün
Here is a picture of my trapezoidal sandwich construction. I want to study the influence of wind blowing over different dimensions of the sandwich construction. For example a different sizes for my ribs. I try to highlight the dimensions in my picture that I want to change.
Old   April 15, 2014, 08:55
Behrooz Jamshidi
Hi
There's no face in fluent, they are just mesh nodes and faces. So you can just scale the mesh. Do you change plate size by scale? if yes no problem would happen, if no how you change the plate size?
Old   April 15, 2014, 11:25
Kathy Grün
I change the dimensions of the geometry in the DesignModeler. I don't understand what you mean with "change by scale" or "just scale the mesh", excuse me.
I want to model different types of sandwich panels, there are panels with high ribs or small ribs with different distances between the ribs.
Thank you.
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
