April 9, 2014, 07:33 |
Fluent solver
Adam
Rep Power: 12 |
Guys, i'm having a pressure-based case with k-epsilon turbulent model which to model air flow from ducting throughout a diffuser (in office or class).
how do i decide my solution solver? (simple, simplec, piso?) and how many iteration do i need? |
April 9, 2014, 10:31 |
Praveen Kumar R
Rep Power: 12 |
SIMPLE, SIMPLEC & PISO are algorithms available in FLUENT to do pressure-velocity coupling. This is to describe how the momentum and continuity equations are coupled. SIMPLE (default) is most robust SIMPLEC - Quicker for simple problems PISO - Quicker for unsteady flows & Stable for highly skewed meshes If your flow is compressible, then you should consider using COUPLED. For most of the cases, SIMPLE algorithm works fine. Happy Learning!!! Praveen Kumar R |
April 15, 2014, 05:53 |
#3 | |
Adam
Rep Power: 12 |
and i wonder on the iteration setup, how do we know or approximate value of iterations to make sure that the calculation is going to reach the exact value? from my case above i'm running up to 3000 iterations, is it consider to be good or not enough? (to approaching exact values) |
Buoyancy and the 6DOF solver (FLUENT) | i2a | FLUENT | 16 | March 20, 2020 11:20 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
FLUENT Solver i strange | BastiL | FLUENT | 1 | July 14, 2008 16:27 |
Changing from STAR to FLUENT - Solver Troubles | BastiL | FLUENT | 0 | February 15, 2008 16:41 |
help required in using six dof solver in fluent | Shah | FLUENT | 1 | February 25, 2006 11:31 |
