Home > Forums > FLUENT
Running Parallel Fluent on a network of two (or more) PCs
Like Tree1Likes
  • 1 Post By ghost82
Old   April 16, 2014, 06:20
Default Running Parallel Fluent on a network of two (or more) PCs
mariachi is on a distinguished road
Hi to all !
Im trying to run FLUENT 14 on two (and later on more) PCs having win64 bit. I have installed all MPIs as well. When i launch it with the option "Distributed memory on a cluster", it gives the following messages as shown sequentially in these pictures. I ignore first two messages by pressing OK and YES.
Please advise in this regard,
mariachi is offline   Reply With Quote
Old   April 16, 2014, 06:23
Cool
p.s. the ping command gives positive reply of network connectivity between the two PCs...
(Apologies if the problem above has been addressed elsewhere, in which case please provide me with a link to that thread )
Old   April 16, 2014, 11:48
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
I don't know the answers to your problem but I would disable windows firewalls on both machines even if the ping command works and make sure you have fluent installed on both machine, in the same directory; make sure you set system variables correctly.
Let us know if and how you solve the problem as I think I will set up a second pc to connect to my workstation.
Read also here:
http://rravikumar.wordpress.com/2013...-distribution/
Daniele
ghost82 is offline   Reply With Quote
Old   April 17, 2014, 04:14
I'm on it Daniele. Thanks for your time!
Old   April 21, 2014, 10:26
shoeb khan
shk12345 is on a distinguished road
actually i wond recommend doing that
the reason being if two pc are connected through lan then the resultant speed decreases becuase of the time data takes to transfer from one pc to another pc.
i have tried doing that several times but never succeeded.
thanks
shk
shk12345 is offline   Reply With Quote
Old   April 23, 2014, 12:45
ghost82's Avatar
Daniele
See here:
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines
mariachi likes this.
Old   May 6, 2014, 09:56
FLUENT 15.0 now runs for me with the option of "Distributed memory on a cluster", following above tutorial:
Thread Tools
Trackbacks are On
FLUENT 14.5 parallel processing on network of computers yhy20081016 FLUENT 6 May 20, 2014 06:36
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Linux Fluent HPC parallel system check failed saad3000 FLUENT 0 October 10, 2013 02:35
running fluent parallel with MS job scheduler Shamoon Jamshed FLUENT 0 November 15, 2009 13:48
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
