April 28, 2014, 04:51 |
#21 |
Maxime Perelli
Rep Power: 41 |
Try to pick BOTH inter and inter:012 and apply coupled
If you cannot, try to set also inter:012 with coupled
In memory of my friend Hervé: CFD engineer & freerider |
April 28, 2014, 04:58 |
#22 |
ayad
Rep Power: 12 |
okay I'll do that later, and I'll show you the result.
thank you so much Mr. mAx |
April 30, 2014, 11:45 |
#23 |
ayad
Rep Power: 12 |
I didn't get the wanted result Mr.mAx. I'll going to try another methods. In coming time if you got any idea about any (flow field and heat transfer simulation ) tell me please.
thank you so much |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
[ICEM] heat exchanger, too much fins | diamondx | ANSYS Meshing & Geometry | 11 | September 24, 2012 19:21 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
