Cant use Automatic Export in Fluent
Old   April 19, 2014, 11:25
Angry Cant use Automatic Export in Fluent
Khalid Ansari
khalidansari4u is on a distinguished road
hi
i m having trouble while using ANSYS Fluent
when i m trying to use Automatic Export it is hidden. so Experts pls help!!!!!!
i m attaching the Screenshot also
khalidansari4u is offline   Reply With Quote
Old   April 20, 2014, 10:53
François Grégoire
macfly is on a distinguished road
Automatic export is only available for transient calculations. If you want to export data in file format other than .dat every X iterations, I guess you have to write a DEFINE_EXECUTE_AT_END udf.
macfly is offline   Reply With Quote
Old   April 20, 2014, 11:13
Khalid Ansari
but i dont even know how to write that
will you pls help me to write that
Old   April 20, 2014, 11:14
François Grégoire
Which file format do you want to export your data to?
Old   April 20, 2014, 15:31
Khalid Ansari
i want to find drag and lift coefficient with time domain
Old   April 20, 2014, 15:33
François Grégoire
Ok now I don't understand, your 1st post implied that your model is steady-state, and now you want to export time-dependent results...
For time-dependent exports you got everything your looking for in the GUI.
Old   April 21, 2014, 03:24
Arrow
Khalid Ansari
ya ya i think i was wrong. this should be transient problem not steady state.
but the question remains, how to give an oscillatory boundary conditions.
Old   April 21, 2014, 08:54
François Grégoire
The question doesn't remain, in each post you're asking a new question!
Clarify what your looking for, search the forum thoroughly for 'oscillatory' etc., tell us what you've tried so far, and then ask a precise question please.
auto, export
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 12:40
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
export fluent data for post-prosessing with fluent hamednoordoost@yahoo.com OpenFOAM Post-Processing 0 May 21, 2013 03:41
Fluent to Radtherm (export of data) akd FLUENT 0 December 3, 2010 01:07
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 08:16
