Hybrid Initialization Failure
Old   February 6, 2014, 05:55
Default Hybrid Initialization Failure
Persil is on a distinguished road
Hello everyone,
I simulate the flow through a turbine. There I get an error, when I try to initialize with Hybrid. It says that convergence criteria (<10e-6) could not be reached and that the pressure in some cells has reached the limit.
If I do more initialization steps, the values get even higher. When just initializing 6 steps, I don't get an error. But calculating from that point, led me to a divergence after 1400 iterations...
Checking the case, did not show problems with the mesh.
- model: energy on, realizable k-epsilon (enhanced wall treatment, viscous heating)
- material: air (ideal gas)
- boundary conditions: pressure-inlet(TI:5, TVR:10), pressure-outlet(Radial equilibrium... BTI:10,BTVR:200)... coupling via Mixing planes between each vane/blade
- solution methods: SIMPLE, Green-Gauss-Cell-Based, rest 2nd Order
- URFs: starting with 10% of default settings
what can I do to enable the initialization or where do I have to look to determine the cause for the error?
Persil is offline   Reply With Quote
Old   February 10, 2014, 10:35
Is there nobody who has an idea, why hybrid initialization failed like this? I'd really much appreciate any feedback
Old   April 23, 2014, 17:57
Liam
LiamH is on a distinguished road
Send a message via Skype™ to LiamH
my experience is that when the initialization does not meet the criteria and instead goes up, that means that there is something seriously wrong with the mesh. Check your max skewness, aspect ratio and min orthogonal quality. If they are showing bad values, that is usually the problem.
LiamH is offline   Reply With Quote
Hybrid Initialization Error Persil FLUENT 11 December 19, 2018 07:59
FMG initialization query Mohsin FLUENT 6 November 2, 2016 02:02
Hybrid mesh generation Jake Main CFD Forum 2 April 21, 2007 14:27
compressor initialization paglia FLUENT 0 February 1, 2006 15:14
Pressure initialization Failure. Nalleli Siemens 2 August 31, 2005 06:28
