July 25, 2012, 19:36 |
Unsteady Combustion
NormalVector
Rep Power: 15 |
I'm having a bit of trouble successfully running a hydrogen-air transient combustion case. The basic geometry is a cylinder with a smaller, short concentric cylinder. Oxygen is introduced at the larger cylinder's cross-section while hydrogen is introduced inside of the smaller cylinder and free to flow out. Both are mass flow inlets. I am able to run a steady state simulation and achieve combustion but when I switch over to a transient regime, the mixture never ignites and remains at the species inlet temperature. I've tried increasing the temperature of both species as to induce ignition but no luck. I've also tried timesteps ranging from 1e-05 to 1e-03 and no luck. Some solver specifics:
July 26, 2012, 00:05 |
Rep Power: 15 |
Unsteady combustion is really awful. Please use spark model for ignition on a point and also try to patch a small amount of species (reactants and products) around the point. I always use it.
Saeed Sadeghi Ansys Fluent CFD Consultant |
July 26, 2012, 02:53 |
NormalVector
Rep Power: 15 |
Thanks, at least I know I'm not the only one who has had trouble with transient combustion. Is this a known problem in FLUENT? I tried a spark earlier today but that didn't do anything, it was merely an increase in temperature. Are there any spark parameters you recommend (spark energy, diameter, etc)?
July 26, 2012, 04:05 |
Rep Power: 15 |
You should increase the spark energy to get a temperature of about 2000K at the point. Also there should be at least a small amount of both reactants and products. Don't forget products should also be around the spark point.
July 26, 2012, 17:33 |
NormalVector
Rep Power: 15 |
Alright thanks, I'll give it a try.
July 30, 2012, 19:17 |
NormalVector
Rep Power: 15 |
Thanks for the help. I was able to get my simulation to combust. Originally, I was using the hydrogen-air mixture template and only included oxygen and hydrogen in the computational domain. When I allowed water to flow into the domain along with the oxygen, the mixture successfully combusted. This was not the case for a steady simulation: the combustion occurred without water present.
April 23, 2014, 05:35 |
fluent spark ignited
qiuyonghai
Rep Power: 11 |
hi NormalVector,i have met the same problem to use the spark ignited,
I am able to run a steady state simulation and achieve combustion but when I switch over to a transient regime, the mixture never ignites and remains at the species inlet temperature, i see you have solved the problem,so i am very desired if you could help me thanks very much |
April 23, 2014, 13:52 |
NormalVector
Rep Power: 15 |
See my post above, try adding a small amount of products into your domain.
April 23, 2014, 14:26 |
#9 |
qiuyonghai
Rep Power: 11 |
thanks for your help,i have do it as you said above, rigion a zone around the spark point,and add 0.01productsand some reactants,but it doesnot work,are there other parameters should notice??? desire for your reply
April 23, 2014, 14:58 |
#10 |
NormalVector
Rep Power: 15 |
The only other thing I would suggest is to initialize your entire domain with a small amount of product. That fixed my problem so if that does not work then I don't know what is wrong with your simulation.
April 24, 2014, 04:23 |
#11 | |
qiuyonghai
Rep Power: 11 |
i give the spark energy 2500j and my inlet is 0.05ch4 0.2 o2 ; i wonder if my inlet boundary conditions set is suited i am very glad to see you reply |
Display Modes | |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
Unsteady combustion test case | doki | Main CFD Forum | 0 | November 19, 2011 06:15 |
time step in unsteady combustion process | FRANK LEE | FLUENT | 2 | July 25, 2007 05:51 |
Unsteady combustion | Newbie | FLUENT | 0 | July 15, 2003 14:08 |
unsteady laminar premixed combustion | seaspace | Main CFD Forum | 0 | August 6, 2002 00:21 |
