2-D double wedge in Hypersonic flow
I am modeling a 2-D wedge in hyper-sonic flow having the following free-stream conditions: Mach no-9.59 Temperature-185.6k Pressure-36.5Pa I have used the following setup in fluent post: Desity based fluid-Ideal gas standard initialization from farfield I tried running the 1000 iterations initially...in which the continuity and energy equations are hardly changing while the x velocity is having a negative slope(convergence), the y velocity is having a positive slope(divergence)..i having tried reducing the cfl value...it is showing the same trend as I increase the number of Iteration...plz sugest how should I proceed:(:(:( |
