Warning: Surface chemistry solver did not converge |
February 27, 2013, 14:15 |
Parisa
Rep Power: 13 |
Hello guys,
I am simulating a surface reaction in FLUENT, finite-rate. When the iteration stats, the following error shows up: Warning: Surface chemistry solver did not converge for 203 cells/faces I reduced the density under-relaxation. Also, I simulated the flow alone to stabilize the flow and after that started to solve surface chemistry, but the above error happened again. Can anyone kindly help me to resolve this issue? Thanks, |
March 12, 2014, 11:58 |
şakir
Rep Power: 14 |
I have same problem. Is there any answer?
April 1, 2014, 15:32 |
vlg
Rep Power: 17 |
I think, very stiff surface reaction mechanism.
There is always this problem with Mr. Deutschmann's mechanisms for me... |
April 30, 2014, 08:03 |
Kostis Chatzi
Rep Power: 11 |
i have the same message-warning.i have imported the deutschmann's mechanism for methane combustion with 24 surface reactions. does this warning affect my results and their validity ?
May 2, 2014, 09:09 |
Maybe 'll help
vlg
Rep Power: 17 |
Surely, it does. You should have high residuals that don't decrease in that case. There are some steps to try:
1) Try to use under-relaxation factors (I usually choose these about 0.7-0.8) for unconverging species and energy equation. 2) After some iterations with URFs you can gradually increase URFs to their initial values (sometimes you can't do this - then stop at max. URFs for that the solution converges). 3) Do more iterations - does the number of unconverged cells reduce? 4) If it doesn't help, try to change advanced solver options. I usually use 1-3 steps. I think, URFs are useful for stiff systems - when we need to use small step for some variables (equations) in iterative methods. It can help to reach the stable steady-state solution (we assume that it exists following by the authors - but it's not necessarily the case). |
May 3, 2014, 11:50 |
Kostis Chatzi
Rep Power: 11 |
thank you for your assistance, villager
Extend Project 1.6-ext Binary Release for Mac OS X | hjasak | OpenFOAM Announcements from Other Sources | 26 | November 5, 2013 16:50 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 19:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
