sliding mesh problem on rotor problem
Old   May 8, 2014, 22:40
Default sliding mesh problem on rotor problem
yang
yida16 is on a distinguished road
Hi guys,
I am now trying to solve a windage problem (air friction loss problem) using Fluent in 2D. I am trying to use sliding mesh now as MRF doesn't seem to work, because I think there's suppose to be a vortex in the flow between the teeth of the rotor when it rotates and MRF won't give me that.
I am now modeling using sliding mesh, attached is my setup, I set a moving mesh around my teeth, called it rotating fluid, the rest of the fluid is absolute stationary. I am not sure if this set up is ok at all as I haven't seen anyone doing it this way. Can someone please help me?
Thanks
yida16 is offline   Reply With Quote
Old   May 9, 2014, 03:07
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi yida,
your setup looks ok, you have to define the interface zones, like MRF anyway.
I suggest reading Fluent Tutorial about Sliding mesh
Regards
Bionico
Bionico is offline   Reply With Quote
Old   May 9, 2014, 09:08
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Sorry,
but I think it will not work as your rotor zone will intersect the stator during rotation; different zones must not intersect during rotation.
Daniele
ghost82 is offline   Reply With Quote
Old   May 12, 2014, 14:54
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
Daniele is right
In both MRF and sliding mesh methods, the separating surface(in 3D problems) and edge (in 2D problems) should be respectively created from a revolution of edge and point about axis of rotation.So your domains are completely wrong.
Use single rotating reference frame and rotate the whole domain.
Regards
CFD-fellow is offline   Reply With Quote
Old   May 12, 2014, 21:27
yang
Originally Posted by ghost82 View Post
Sorry,
Daniele
Hi Daniele,
Thanks. So what should be a correct way to set up the problem? If I use SRF/MRF, there will just be steady flow, if no inlet/outlet is defined. And the torque on the teeth are just close to zero
Should I set a inlet/outlet? If so, how should I set it up?
Thanks
Old   May 12, 2014, 21:32
yang
Originally Posted by CFD-fellow View Post
Hi
Daniele is right
Regards
Hi CFD-fellow,
Thanks for the reply, same as the question to Daniele,
SRF/MRF will give me steady flow and I will see torque close to zero on rotor surface. The teeth of the rotor was supposed to generate vortex in the flow. In addition, I cannot use wall motion for the rotor surface since the teeth of the rotor are normal to the direction of flow
I really appreciate your help
Old   May 13, 2014, 00:29
yang
Hi
Daniele is right
Regards
I mean, this is like a immersed solid problem in CFX, a rotor rotating in air bounded by walls. Is it possible to do it in Fluent?.
Thanks
Old   May 13, 2014, 04:08
Behrooz Jamshidi
Yes its a common task to be handled by Fluent.
>Mesh your domain so that you have just one domain.(because of small gap between teeth tip and wall, it is not recommended to create two domains, but as i said your domains are incorrect and you cant judge on Fluent results by this)
>In settings of your domain choose moving mesh for its motion(this is sliding mesh and the rotor really rotates and solver is transient)
>Also you can set moving reference frame to this domain and use its results as an initial condition for moving mesh.
>Be sure that in this way the difference between MRF and sliding mesh torque would not be so much.
Old   May 13, 2014, 10:32
yang
Hi CFD-fellow
Thanks for your advice. I tried your way but it seems that the flow is steady under your method. Attached are the pressure and velocity contours. I also tried sliding mesh, but it reaches steady flow also. From my understanding, the teeth on the rotor are suppose to generate vortex in the flow, I am not seeing that effect at all. I don't have much knowledge in fluid dynamics but from one paper about gear windage loss, I see that effect, and this problem is just like that.
Any good suggestions?
Thanks for your patience
Old   May 13, 2014, 10:39
yang
Here's the paper
http://www.wseas.org/multimedia/jour...012/54-646.pdf
He also used Fluent, and defined teeth as rotating wall but fluid seems to be stationary... I don't know how he did that because there are walls normal to the direction of rotation and the rotating wall in fluent will ignore those parts.
Old   May 13, 2014, 11:16
Behrooz Jamshidi
Please attach a picture of display>vectors>relative velocity or velocity magnitude.
I havent read the paper(the paper and their authors both are not expert) completely, but if their domain is stationary and the teeth are rotating wall, it is completely wrong.
Old   May 13, 2014, 18:07
yang
Hi CFD-fellow,
Have you seen the contours above?
Attached is the vectors for velocity. The flow is steady, which I think is not correct for my case. The tooth is supposed to generating interrupts in flow according to my limited knowledge.
Thanks
Old   May 14, 2014, 04:02
Behrooz Jamshidi
Hi
I suppose that you know the pressure and suction sides definition in turbomachinery. In your pressure contour the pressure on both suction and pressure sides are equal in the same radial position and this is not true. There is something wrong in your setup that I cant guess until seeing your complete setup and mesh.
Fluent tutorials also will be so helpful.
Old   May 14, 2014, 09:49
yang
Hi
Hi CFD-fellow,
Thanks
I looked upon the pressure and suction.I was wondering why the two sides are same too. But I defined a moving wall with 0 velocity relative to the fluid, so I guess that will just make the wall stationary with respect to the fluid, which will make the pressure same?? For my rotor, the two sides of the teeth are exactly the same shape, so it is probably different from common turbo problem.
Thanks
Old   May 14, 2014, 21:50
yang
Hi
I forgot to mention that I don't have inlet/outlet... Is that the issue. I honestly don't know how set them, since I am not pushing air in any direction?
Old   May 15, 2014, 07:08
ghost82's Avatar
Rick
What is the rotational speed?
Old   May 15, 2014, 10:21
yang
Hi Daniele,
It is 15000RPM.
fluent, sliding mesh, windage
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 21:54
Sliding Mesh Problem CC FLUENT 1 February 8, 2009 23:26
Sliding mesh problem Michel FLUENT 1 January 15, 2009 10:18
