January 15, 2012, 07:44 |
cyclone analysis error
arjun
Rep Power: 14 |
hi all,
i am working with analysis of cyclone dust collector. i have followed the cyclone tutorial available with me. but while running the simulation in FLUENT i found following error. reversed flow in 140 faces on pressure-outlet 13. # Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size! # Divergence detected in AMG solver: mp-x-momentum -> Increasing relaxation sweeps! # Divergence detected in AMG solver: pressure correction -> Turning off correction scaling! # Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps! Error: Divergence detected in AMG solver: pressure correction Error Object: #f please help me. |
January 15, 2012, 08:32 |
Rick
Rep Power: 26 |
this means that the solution diverges: - what model are you using? (you can use k-epsilon RNG with swirl dominated flow enabled, solve for flow and then turn on dpm injection(s)) - what resolution methods? - are you sure you have a good quality mesh? - what boundary conditions? (you can use outflow as outlet boundary and velocity inlet as inlet) - the solver diverges when you start simulation or after how many iterations? - steady or unsteady simulation?If unsteady what is the time step? Daniele |
January 15, 2012, 08:56 |
arjun
Rep Power: 14 |
i get this error after 11 iteration.
solution is not diverged. i am using steady state analysis. minimum mesh quality is 0.5. second order scheme. with velocity inlet and outflow boundry conditions. it gives error. solution is not diverged at all. |
January 17, 2012, 08:09 |
#4 | |
shoeb khan
Rep Power: 14 |
You can try as following steady analysis is ok!! mesh size doesn't matter much for divergenve. use first order scheme. use velocity inlet and pressure outlet bc. try to solve flow first and then inject the particles into the domain use a lower value for momemtum and pressure for underrelaxation factor try to change your mesh type. regards shk |
May 15, 2014, 01:05 |
Multiphase phase (gas-solid) flow using DDPM MODEL medel ( divergence problem
Hi every one....
i am trying to simulate a solid-gas fluidized bed USING DDPM +DEM MODEL I GOT FOLLOWING ERROR # Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size! # Divergence detected in AMG solver: mp-x-momentum -> Increasing relaxation sweeps! # Divergence detected in AMG solver: pressure correction -> Turning off correction scaling! # Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps! Error: Divergence detected in AMG solver: pressure correction Error Object: #f THANKU IN ADVANCE |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
