Gas turbine combustor modelling - uburned fuel at the outlet |
May 14, 2014, 06:56 |
Andrea
Hi everybody,
I am modelling a DLE micro gas turbine combustor using the partially premixed model in Fluent. I have noticed that using the steady flamelet model with GRI3.0 chemical mechanism the temperature at the combustor outlet is significantly underpredicted. After a short investigation, I found that I have a significant percentage of uburned fuel at the outlet (mass fraction of CH4 at the outlet is about 3e-3 which is very high). The same problem is present using Chemical equilibrium approach instead of the steady flamelet. I do not face this problem using the eddy dissipation model (CH4 at the outlet is of the order of e-8, as it should be) and the outlet temperature value is correct. Any idea on what is going on with the partially premixed model? Cheers Andrea |
Temperature distribution for gas turbine inlet conditions | Aerogirl | FLUENT | 1 | February 19, 2012 15:20 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Gas Turbine Combustion Data | cfd_user | Main CFD Forum | 1 | August 13, 2000 20:20 |
flow in gas turbine | Abdul Hafid | Main CFD Forum | 1 | September 14, 1998 09:39 |
