Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem)
Like Tree1Likes
  • 1 Post By jipaz
Old   January 27, 2011, 21:45
Default Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem)
jessie is on a distinguished road
Hello everyone,
I'm facing a problem in modeling a FCC riser. I am using an Eulerian granular multiphase model to simulate the flow pattern. A 3-D, steady state, k-e turbulent, non-reacting, isothermal flow is being simulated using the E approach. There are two phases in the riser right now, gas and solid. There are two different gases flowing into the system from two different inlets and the particle feed into the riser from one of the inlets.
The problem is when I change the drag coefficient relationship between the two gases and the particle from schiller-naumann to syamlal-obrien, the case just diverged. I already tried different meshes and reduced the relaxation factor, however there is no improve at all. The fluent showed "Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size!......"
If I just use the schiller-naumann, the case can converge. And if I just simulate the flow of one gas and the particle using syamlal-obrien or two gases, at least the case would not be diverged. Does anyone have any idea why this is happening and how can I fix it?
Your help will be appreciated. Prior thanks for your assistance.
jessie is offline   Reply With Quote
Old   January 28, 2011, 01:09
Angie
Angeline is on a distinguished road
use unsteady simulation.......
Angeline is offline   Reply With Quote
Old   January 28, 2011, 10:09
Hello Angeline,
I tried unsteady condition, but the case still diverged.
Your reply is really appreciated.
Old   May 29, 2014, 11:05
jipaz is on a distinguished road
Hi Jessie:
I have almost the same problem, I'm simulating a 2D riser with two phases gas-solid. I've been using Syamlal-O'Brien drag model until now and everything has run ok.
The I changed the drag model to EMMS, and I got
# Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size!
Divergence detected in AMG solver: pressure correction
at the very beginnig of the simulation, it does not start to converge.
Every previous research work sets as inital conditions that "no gas or air into the riser" so I understood that Vg=0, Vs=0, and vol fraccion of solids=0, what it means that at the begginig the riser is full of static air, and not solids at all.
I changed the initial condition setting Vg=5.2 m/s, and the simulation runs for 3-4 iterations but it crashses again, now only with
Divergence detected in AMG solver: pressure correction, error.
Did you solve your problem?
Is correct to set Vg=0, Vs=0, and vol fraction of solids=0 when "no gas or air into the riser" is said?
Thanks in advaced,
Ignacio
killas1994 likes this.
jipaz is offline   Reply With Quote
eulerian multiphase model, gas-solid flow, granular
2 phase flow liquid flow solid particles sachin OpenFOAM Running, Solving & CFD 0 August 28, 2008 16:51
Problem on boundry of two phase flow youngan CFX 2 June 30, 2003 02:11
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 03:24
