May 31, 2014, 07:18 |
capillary pressure and surface tension
Ebrahim
Rep Power: 12 |
Hi
Imagine a porous region is saturated with a liquid (e.g. water), and another fluid is entering to the porous region: Is it necessary to consider capillary pressure and surface tension between fluids in the Fluent modelling and how can it be done? thank you |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
Access the surface tension force at a patch | michielm | OpenFOAM Programming & Development | 1 | December 13, 2013 03:50 |
free surface problem with capillary effect | rabbitmelon | CFX | 25 | August 16, 2013 03:05 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 12:19 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
