DT_CG use
Old   June 26, 2014, 06:09
Default DT_CG use
hannecart
Isitv2A is on a distinguished road
i want to know the position of CG for this i use in my udf the DT_CG(dt)
for( i=0 ; i<3; i++)
x_cg = DT_CG (dt) ;
where x_cg habe been declared as a real .
message error (" impossible de convertir de 'real *' en 'real' ")
can someone explain me how to use correctly DT_CG ?
thanks !
Isitv2A is offline   Reply With Quote
Old   June 26, 2014, 08:15
pakk will become famous soon enough
DT_CG is a vector (with 2 or 3 dimensions).
So you should also define x_cg as a vector.
real x_cg[ND_ND];
And then assign it using:
NV_V(x_cg,=,DT_CG(dt));
I think.
pakk is offline   Reply With Quote
Old   June 26, 2014, 10:07
hannecart
ok i will try
at first i declared x-cg like that " real x_cg[3) " to have a vector 3dim
than i use a loop to define x-cg[i]=Dt-cg(dt) [i]
