June 3, 2014, 21:39 |
Spalart-Allmaras y+
Karla
Rep Power: 12 |
Hi!
I am running an aircraft simulaction in Fluent Ansys 15 in cruise condition (M=0.8, h=11km...). I am using a SA model and I have read that the y+ value must be y+=~1 or 30<y+<150 but I am a little bit confused about it. Is it correct? And why is there this difference between the two ranges? Thank you very much! |
June 4, 2014, 04:34 |
Flavio
Rep Power: 15 |
Hello Mr. Pinka,
if you choose a k-epsilon turbulence model, you can define the Near Wall Treatment: it depends on your Y+ (Enhanced Wall Function for Y+=1 and Standard Wall Function for Y+>30). Spalart-Allmaras doesn't let you to change the Near Wall Treatment, so I suggest reading Fluent Manual: probably this turbulence model can switch automatically from a function to another according to Y+ (as Scalable Wall Function). Kind Regards
Bionico |
June 4, 2014, 05:42 |
Karla
Rep Power: 12 |
Thank You Bionico,
Yes, I have been reading the Fluent Manual and I have found that the Y+ Value must be Y+~1 or Y+>30 for Sparlat-Allmaras model. I suppose that the model use a wall funtion for Y+>30. If somebody disagrees please tell why. Thank You! Regards! |
June 4, 2014, 07:23 |
Rick
Rep Power: 26 |
Yes Karla, from fluent manual:
In summary, for best results with the Spalart-Allmaras model, you should use either a very fine near-wall mesh spacing (on the order of ) or a mesh spacing such that . |
June 4, 2014, 07:26 |
Karla
Rep Power: 12 |
Exactly Ghost82,
Thank You very much for the reply. Regards |
Spalart and Allmaras Paper | Mohamed | Main CFD Forum | 7 | July 10, 2014 16:39 |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 10:53 |
Spalart Allmaras Paper | Seroga | Main CFD Forum | 0 | April 7, 2008 02:48 |
spalart allmaras paper | hafiz | Main CFD Forum | 1 | April 10, 2007 03:47 |
extracting K and Epsilon from Spalart Allmaras | Sundar | Main CFD Forum | 4 | July 31, 2006 02:02 |
