fatal signal (ACCESS_VIOLATION)
Hi all,
I have been faced with this error when I do the run right after the first time step: Error: C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0 tx86\2ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f Code:
I guess your problem might be in the following two lines:
real NV_VEC(pt); NV_D(pt,=,xmin,ymin,zmin); I have no clue what your intention for variable "pt" was, but this is definitely a wrong way to define it. And you never use it... So either just delete those lines, or if you think you need it, change these lines into what it should be and use it. |
thanks for your reply,
I was tested the case file with another computer( a LINUX system with installed Fluent 14.0 )and the case has been compiled without any error and the calculation completed. I am wondering, why the error arises only when I do compiling in my system installed Fluent 14.5 windows 7-64bit. regarding to your doubts, I am doing a 3D-transient analysis, tend to get temperature of a point for each time step and immediately giving the comment (in regard to the set temperature point) to the heat source in order to be ON or OFF. regards, |
