one piston dynamic deforming and mesh moving simultaneously
Old   June 20, 2014, 07:08
Default one piston dynamic deforming and mesh moving simultaneously
John Lu
john Lu is on a distinguished road
Hi, everyone
I am doing a simplified simulation about one piston deforming axially(Z axis) while moving directly along X axis simultaneously.
Firstly, for piston deforming:
I defined the piston bottom as a rigid body, the udf program is:
#include<stdio.h>
#include<math.h>
#include"udf.h"
DEFINE_CG_MOTION(piston, dt, vel, omega, time, dtime)
const PI=3.1415926;
vel[0]=-0.1;
vel[2]=-((0.771*sin(50*PI*time))/(1-0.0085*cos(50*PI*time))/(1-0.0085*cos(50*PI*time)));
while vel[2]defining the piston bottom moves along Z axis, vel[0] describing piston body move along X axis.
the piston cylndrical surface is defined as deforming, the geometry of which is defined as cylinder.
Secondly, for the piston movement, which is defined in "cell zone conditions" the X axis translational velocity is defined as -0.1m/s, the same as written in udf.
However, preview mesh motion shows negative cell volume.
What's the reason?
P.S.
If only dynamic mesh is used, no problem.
If only mesh motion is used, no problem.
But, if two of them are used, negative cell volume occurs.
john Lu is offline   Reply With Quote
Old   June 20, 2014, 07:13
John Lu
It seems that, once the piston cylndrical surface is defined as deforming-cylinder, which would not move though the piston movement is defined in "cell zone contions- mesh motion".
deforming and moving
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
moving mesh rolling piston JohannVV FLUENT 4 November 11, 2010 09:46
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
Moving and deforming mesh paolo FLUENT 0 June 19, 2003 08:12
udf for moving and deforming mesh xie haibo FLUENT 4 October 27, 2002 06:45
