Problem with stirred mixing tank
Old   June 20, 2014, 09:16
Default Problem with stirred mixing tank
amine
aminem is on a distinguished road
Hi
You can see in attached picture that I have a probleme with water velocity
Can anyone help me de resolve this problem ?
I used MRF and k-e RNG approach
W= 100 rpm
material: water
solver: SIMPLE
Meshing : non conformal patch (see picture)
aminem is offline   Reply With Quote
Old   June 20, 2014, 10:29
amine
Problem are solved
Old   June 20, 2014, 10:31
Sun
Sun's Avatar
Sun is on a distinguished road
A few suggestions:
try k-e standard, slice your geometry at the bottom part, I believe you can get hex elements for the Rushton blades and try different dimensions for the rotational zones
And a couple of questions:
What component of the velocity is the first contour?
Could you please attach the contour plot of axial velocity in a vertical plane (xy in your geometry)
Please include the number of cells and the mesh quality in your reply.
Overall, I think the mesh is causing all the troubles. To me it looks kinda coarse, especially where the top rotational zone touches the rest of the tank.
Cheers!
Sun is offline   Reply With Quote
please help,open tank problem raju FLUENT 1 January 28, 2020 01:49
[GAMBIT] geometry and griding a stirred tank prec ANSYS Meshing & Geometry 12 May 22, 2014 12:46
stirred tank nilesh Main CFD Forum 2 September 27, 2006 00:26
problem with MFR model for multiphase mixing tanks Srinivas Main CFD Forum 1 November 7, 2005 14:16
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
