convergence in rsm
Old   June 23, 2014, 01:47
Default convergence in rsm
sharath21 is on a distinguished road
hi guys ,
i am doing a problem of flow over a sphere for a reynolds number from 1.2*10^5 to 2.42*10^5 i am planning to use the rsm model
after many trail and errors i found that i was going nowhere
so i am in desperate need of some expert advice please help me!! i would dearly appreciate it
ok so i have the the following questions
1)i have a y+ of less than one everywhere on the boundary so i am using rsm i.e
the stress omega version with low re correction on is it ok for my flow which is unsteady with flow separation
2) is it requried that the flow be converged at every time step?
if so then what changes should i make regarding
a)setting of initial conditions i.e for turbulent intensity and
other parameters
b)it was suggested that i use the PISO scheme for Pressure-
velocity Coupling rather than SIMPLE is it justified?
c)what should the quality of the mesh be in terms of the skewness and aspect ratio .Is a skewness of 0.8 allright ?and an aspect ratio nearly 200 and 350000 cells
3)is there a need for me to adapt the mesh?
4)many people suggested that i first run the simulation for a steady state k epsilon to get the boundary conditions but they give very bad results and do not converge as my flow is unsteady
5)the transition takes place at an re of 3.8*10^5 so should i be looking at transition models? how well does rsm work for transition flows?
6)i am using turbulence intensity of 1% at both inlet and outlet and hydraullic diameter as my sphere diameter for both inlet and outlet as i read that for external flows the turbulent intensity is less than 1
7) the domain i used for my problem is a spherical domain which is ten times bigger than my sphere but i am suspecting that to capture the wake i need another type of domain what is your opnion ?
sharath21 is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
convergence in rsm sharath21 ANSYS 0 June 22, 2014 15:12
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
RSM convergence khar FLUENT 1 May 11, 2008 15:50
