Home > Forums > FLUENT
Venturi pressure not being conserved!
Old   June 23, 2014, 16:22
Default Venturi pressure not being conserved!
criville'99 is on a distinguished road
Hi all,
I am currently validating Bernoulli' principle in a venture. There are no pressure inlets on the throat / neck of the venture (just an inlet and an outlet).
I am trying to validate the principle first (higher pressure > lower velocity and vice versa).
The problemI have at the moment is that the pressure does not appear to be conserved. It should be noted that I am viewing the static pressure from a 'line' I have drawn that runs through the centre of the inlet through to the outlet.
When I view the static pressure on the XY plot I get a flat line reading 'ZERO' Pascal.
If I view the velocity magnitude from the wall of the venture, a good increase / decrease can be seen (as to be expected).
However I am unable to get the same for the pressure reading (regardless of what surfaces the plot comes from.
I have tried decreasing the velocity (to reduce losses), tried an outflow for the outlet, various schemes, changed relaxation factors but to no avail!!
Problem setup:
Solver: pressure based
Velocity formulation: Absolute:
Time: Steady
Turbulence model: energy equation off, K-e, enhanced wall treatment, all other settings are default
Material: water / liquid (Ansys library)
Boundary Conditions: inlet (velocity inlet), outlet (pressure outlet), Wall (stationary wall)
Pressure: all gauge pressures are set to zero, the operating pressure is set to 101,325 Pa
Any help on this would be highly appreciated
criville'99 is offline   Reply With Quote
Old   June 24, 2014, 12:14
Default No change in static pressure in Venture
--- Anyone?
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 2 September 12, 2012 06:15
Difference between pressure, absolute pressure and Total Pressure shaswat CFX 1 September 6, 2012 06:12
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
