June 27, 2014, 03:34 |
Nanofluid particle size
Gourav
Rep Power: 11 |
Hey, Im modelling flow of nanofluids in circular tube. I needed to know how to set the size of nanofluid particles in Fluent. I need to set it at 100 nm, so where can i input this data?
Thank you in advance. |
June 27, 2014, 04:52 |
Mustafa
Rep Power: 12 |
Look my friend you can model as single phase with modified fluid properties .There are some
equations to modify fluid properties due to the presence of particles . |
June 27, 2014, 06:38 |
Gourav
Rep Power: 11 |
I'm modelling for both single phase and double phase. Also the fluid properties that i defined depends on the volumetric concentration of the particles in the base fluid. So Im not sure where exactly is the size taken into consideration.
June 27, 2014, 06:48 |
Mustafa
Rep Power: 12 |
I don't think that fluent can model such sizes
November 23, 2014, 11:36 |
Hi Gourav
I am also working on nanofluid simulation. Kindly tell me if you have found any solution to your problem of setting particle diameter in single phase flow
https://t.me/pump_upp |
January 5, 2015, 12:08 |
sim nanofluid
hamid sadeghianmehr
hi
i use this paper and be useful for me....Untitled.jpg |
January 5, 2015, 12:11 |
Thanks ahoora360
July 10, 2015, 05:49 |
Rep Power: 10 |
wat is the solution ?? where to give input data for size ???
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
