Solid spherical bubbles in fluid
Old   July 1, 2014, 08:08
Default Solid spherical bubbles in fluid
Martin Mazurowski
Mazur is on a distinguished road
Hello every one!
I have a small problem with big bubbles.
I want to prepare a multiphase simulation in fluent where I have 20 spherical solid (glass) "bubble type" bodies with diameter of 2mm, which are placed in a tank filled with water. Tank diameter is about 15mm. Those bubbles are moved by the fluid stream coming with a pipe from side. I Have an existing real part and I know how the bubbles will move. I first made an analysis of flow in that cylinder, and the flow pattern corresponds to the real one. But in this simulation the behavior of those bubbles is the point of interest, and they have the ability to collide witch each other.
All multiphase tutorials/documentation which I found showed simulation of very small particles - fluid multiphase flows. (something more like sand - water). Where should I search for clues, because unfortunately I don't know where to start? I would appreciate for every suggestion/key words where should I search for the answer?
Best Regards.
Mazur is offline   Reply With Quote
Fluid Solid Interface in Fluent saisanthoshm88 FLUENT 2 July 17, 2012 05:31
goddamnit: how to set up heat transfer from fluid to solid macfly FLUENT 7 June 16, 2012 11:50
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? awacs OpenFOAM Running, Solving & CFD 6 September 22, 2009 22:58
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 11:41
