2D Axisymmetric airfoil cannot report lift!!! |
July 5, 2014, 09:10 |
Andy
G'Day
I'm trying to compare the stall behaviours or an aerofoil in standard planar configuration and Axisymmetric configuration to see if the stall point changes significantly. I am trying to design a difuser for a wind turbine for my bachelor thesis. The probem is, whist I have had no problem reporting the lift force created by an aerofoil in standard 2D configuration, in axisymmetric setup the Y component of force just reports as zero. This is not physical. Unless of course it is reporting the net force for the whole diffuser ring. Whilst I do understand the conundrem that in axysymetric configuration the 'lift' force is radial and not strictly in the cartesian Y direction, it is in the Y direction according the slither modeled by the mesh so I expect it should be possible to report lift. But I cannot find any other way to report forces from an axysymetric simulation. Is there any way I can report force in the radial direction? I can understand it may be be in N/rad or somesuch unit |
July 11, 2014, 00:41 |
Andy
Really? No-one's got anything???
2d fluent help needed |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
2D Inviscid Airfoil model zero lift angle | HutchMan | FLUENT | 8 | December 9, 2012 15:04 |
airfoil 2D simulation: position of lift force on the airfoil | Koenieboy | Main CFD Forum | 2 | March 13, 2012 06:44 |
