What Surface Monitor to set to find Mass Flow Rate? |
July 12, 2014, 04:17 |
Michael
Rep Power: 11 |
Hey guys,
I'm trying to find the mass flow rate of my flow as it enters into my passenger cabin. However, I'm not too sure what type of surface monitor I should set, and how I should set it. I've tried using a "point" surface monitor in FLUENT, but it always ends up giving a value of "0". Should I use a line? a plane? And if so, how should these be oriented? What type of "report" should I be choosing if I wanted to check for flow velocity convergence? Mass-Weighted Average? For example, I'm trying to monitor the flow as it just enters into the cabin, and maybe around the driver head area. How should the surface monitors be oriented? Thanks alot guys! |
July 14, 2014, 09:35 |
Anonymous
Rep Power: 13 |
You can use the 'mass flow rate' report type in surface monitors and you should calculate mass flow rate through a surface.
You can also calculate the mass flow rate in CFD-post by using the function calculator. I find it a little easier to use CFD post to create planes. |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 21:02 |
Split Mass Flow Rate in ANSYS CFX | ashtonJ | CFX | 2 | July 9, 2014 03:08 |
Surface inejction- steady state - mass flow rate | CFD-student | FLUENT | 0 | January 25, 2012 13:40 |
Surface Integral - Mass Flow Rate | Venkatesh V | FLUENT | 3 | October 10, 2008 16:18 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
