regarding thermal analysis in a bulb of type halogen |
October 25, 2014, 14:54 |
anbu
Rep Power: 12 |
hi cfd user,
: a help regarding thermal analysis in a bulb. A bulb type halogen which power is 70w,produce 90 percentage of heat where filament gets heated upto 4000c but on the bulb surface temperature noted 400c in experimentally,but in cfd how is it possible. As area is small between the filament and glass surface the heat transfer takes quickly and getting high temp on bulb surface |
Display Modes | |
inlet pressure is higher than outlet pressure for fan | sivakumar | OpenFOAM Pre-Processing | 16 | December 30, 2017 14:16 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
Problems with a barrier in a river | faerber | OpenFOAM Running, Solving & CFD | 2 | July 6, 2014 22:29 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
