September 5, 2019, 10:07 |
Zero gradient pressure
Liliana de Luca Xavier Augusto
Rep Power: 13 |
Hi all,
I have a geometry of two paralell plates with a whole in the middle (like two paralell CDs). One of these plates is rotating, and the axis of rotation is in the middle of the geometry. The figure can be seen here: https://drive.google.com/open?id=1DB...dp8UQurfpQ67Fz. I would like to use a zero pressure gradient as boundary condition. Consider that the inlet BC is the small space between the parallel plates closer to the middle of the geometry (the inner radius). The outlet is the space between the parallel plates at the far end of the geometry (the outer diameter). I have used an Inlet Pressure BC equal to zero (gauge total pressure) and at the outlet I have used an Outlet Pressure BC equal to zero (gauge pressure). However, I am getting a very weird result: when I check the mass flow rate at the inlet, I get a negative value and at the outlet, a positive value. It is like fluid is going to the outer radius from the inner radius. The radial velocity component also confirms this behaviour. Does anyone know why this is happening? Thanks in advance for any help! |
Display Modes | |
UDF for zero pressure gradient at BC outlet | ghordog | Fluent UDF and Scheme Programming | 1 | April 28, 2022 05:12 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
negative pressure gradient in cone-shaped pipe | Pawel Zdunek | Lounge | 0 | April 29, 2017 15:16 |
how to get pressure and pressure gradient using UDF | Honglin | Fluent UDF and Scheme Programming | 0 | May 24, 2012 06:47 |
Inputting pressure gradient in Fluent | Josyula | FLUENT | 2 | December 23, 2009 07:26 |
