Magnitude of .cas file is changed.
Old   July 24, 2014, 21:09
Default Magnitude of .cas file is changed.
Sangwoo Kim
swtbkim is on a distinguished road
I had a .cas file, abc123.cas
I imported it in FLUENT, and iteration is over.
I saved the results in different name.
These are def456.cas & def456.dat
The magnitude of abc123.cas is 606MB, but that of def456.cas is only 405MB.
What happened here??
It happened in my case only?
If not, what kind of information is deleted or transferred?
If transferred, to where?
I didn't find a weird thing in def456.cas file yet, but I'm worrying that there may be some significant change or lack.
Thanks in advance.
Best regards
swtbkim is offline   Reply With Quote
Old   July 25, 2014, 00:31
blackmask will become famous soon enough
Perhaps due to case file saved in ASCII or BINARY mode.
blackmask is offline   Reply With Quote
Old   July 25, 2014, 01:14
Sangwoo Kim
Thank you for reply.
Can you explain details? I don't understand what you mean.
Anyway you mean this is not uncommon?
Best regards
Old   July 25, 2014, 04:33
It is common. After reading your either case file, click File/Write case file, see the difference between files when you check and un-check "Write binary files" option.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 05:26
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
