Home > Forums > FLUENT
problem with convergence!
Like Tree3Likes
  • 1 Post By sara22
  • 1 Post By RodriguezFatz
  • 1 Post By swtbkim
Old   August 9, 2014, 11:30
Default problem with convergence!
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hey!
I have a problem with convergence in my project!
I'working on a centrifugal compressor and its diffuser!
The solver specifications is:
Density based solver
Air-ideal gas
K-epsilon turbulence model
My problem is non-convergent the solution!
As appear in the attached picture, the residuals of continuty and energy is not convergent!
Do you have a suggestion for me to help the residuals convergence!?
Tnx
amin.z is offline   Reply With Quote
Old   August 11, 2014, 04:28
Sa.Baraty
sara22 is on a distinguished road
Hi
please check your mesh quality. Maximum cell skewness and orthogonal quality are important parameter for solution converge.
amin.z likes this.
thanks
sara22 is offline   Reply With Quote
Old   August 11, 2014, 05:51
amin.z's Avatar
Amin
Originally Posted by sara22 View Post
Hi
Slm!
Tnx for your reply!
Because the number of elements was too great (about 6,500,000 elements),I had to reduce them (to abaut 2,500,000).
As you referred, probably the mesh quality is cause of the problem!
Old   August 11, 2014, 06:35
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
In your residual plot you just show a few hundred iterations. I would not expect such a large mesh (2.5 mio) to converge that fast. You probably just need more iterations (except your intialization already is really close to the final result).
amin.z likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 11, 2014, 07:41
amin.z's Avatar
Amin
Hi!
Oh!realy? Do you believe if I continue the solution it can be converge?
Because I don't see any convergence sign for energy and continuity, I guess it could not to convergence and I stopped the process!
Tnx dear Philipp for your help!
Old   August 11, 2014, 07:42
Philipp
Well, this could be the reason. But before you didn't try, I would not try to change anything else.
Old   August 11, 2014, 07:57
amin.z's Avatar
Amin
Because the solution time was too long ( 15 min for 10 iterations! ) I decided to no more iteration! But as you said, I will continue the solution and I hope that the problem would converge!
How many iterations you're guessing would be required!??
Old   August 11, 2014, 08:48
Philipp
Good question. I would try 500 more and see if there is any development...
Old   August 11, 2014, 09:55
amin.z's Avatar
Amin
I will continue the solution for more than 500 iterations
And
According your experience, for a turbocharger with centrifugal compressor which type will be better in solution control for flow? 1st order or 2nd order or 3rd order MUSCL or QUICK? (Current solution was based on 1st order!)
Very grateful!
Old   August 11, 2014, 09:56
Philipp
Sorry, I don't have experience with that. It was more a general hint, that you should not expect convergence too soon with such a large grid.
Old   August 11, 2014, 11:53
amin.z's Avatar
Amin
Ok!
Anyway, thank you dear friend!
Old   August 12, 2014, 02:51
Sangwoo Kim
swtbkim is on a distinguished road
Everything can cause a divergence.
Mesh quality and the number of iteration which Phlilpp and Sara suggest are strong candidates.
If you have enough time, I recommend to start from the simplest model first.
If you are using MRF, moving wall, or whatever, shut all of them off and start just with turbulence model. If it looks like behaving favorably, then change the scheme from 1st order to 2nd order, and add more complex models step by step.
In my experience(of course it can be different issue in your case) especially energy equation is important. I never begin the first calculation with energy equation.
amin.z likes this.
Best regards
swtbkim is offline   Reply With Quote
Old   August 12, 2014, 04:40
amin.z's Avatar
Amin
Dear friend! Thanx for your reply!
I'm using mesh motion and the model has a grid interface!
The compressor is rotating with 20,000 rpm and its output exits from 2 outlets!
Also I'm checked this model with increasing angular velocity step by step (5000 & 10,000 & 15,000 & 20,000 rpm) but the convergence issue for energy and continuity exists!
Based on your suggestion, I will try the solution as non-rotating fluid and only with turbulence model!
And in your oponion, is it possible that "no existing of boundary layer mesh" and "great y-plus" be reason of this divergence!??
Best regards
Thread Tools
Trackbacks are On
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
