Fluent giving different results for the same analysis
Old   August 15, 2014, 03:14
Default Fluent giving different results for the same analysis
Burak Kaya
ferroburak is on a distinguished road
I'm analysing a 2d model of a centrifugal pump using steady k-epsilon turbulence model. I iterate the fluent 5000 times. I use 2d mode, not 2ddp. Residual convergence criteria is 1e-5 for k,epsilon, x velocity, y velocity, continuity.
I get different results each time I run the model. What could be the reason? Should I increase the number of iterations, or decrease the convergence criteria?
Thanks in advance.
ferroburak is offline   Reply With Quote
Old   August 15, 2014, 03:43
Burak Kaya
I'm changing the option to 2ddp to see if it solves my problem.
Edit: It didn't solve my problem.
Old   August 15, 2014, 03:53
pakk will become famous soon enough
What do you mean with "different results". Slightly different or completely different?
pakk is offline   Reply With Quote
Old   August 15, 2014, 06:27
Burak Kaya
Pressure values are 10% or so different for the same setup(same .msh file).
I use a velocity inlet, a pressure outlet, and wall boundary condition at the blades.
I want to use the result for an optimization work.
Old   August 15, 2014, 07:06
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
The equations you solve for are deterministic. For a given set of initial conditions you will always get the same result. Obviously, you do something (unintentionally) different each case you run it.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 15, 2014, 10:22
Burak Kaya
I think I spotted the problematic portion of the journal file:
yes
"C:\Users\bpehlivan\Desktop\2dpump\ga17\mass_flow_ rate_v2.flp"
re/si
a-w-a
2
6
total-pressure
yes
"C:\Users\bpehlivan\Desktop\2dpump\ga17\total_pres sure_v2.srp"
re/si
q
exit yes
I'm getting the following message on fluent when I run the fluent journal file:
> re/fl/mf
all boundary/interior zones [yes] no
Zone(1) [()] 5
Zone(2) [()] 9
Zone(3) [()]
Write to File? [no] yes
filename (*.flp) [""] "C:\Users\bpehlivan\Desktop\2dpump\direct1\mass_fl ow_rate_v2.flp"
> re/si
/report/surface-integrals> a-w-a
surface id(1) [()] 2
surface id(2) [()] 6
surface id(3) [()]
area-avg of> total-pressure
filename (*.srp) [""] "C:\Users\bpehlivan\Desktop\2dpump\direct1\total_p ressure_v2.srp"
/report/surface-integrals> re/sinvalid command [re]
i
area flow-rate sum
area-weighted-avg integral vertex-avg
facet-avg mass-flow-rate vertex-max
facet-max mass-weighted-avg vertex-min
facet-min standard-deviation volume-flow-rate
So, I think there is a problem when writing the pressure to the file.
Old   August 15, 2014, 10:25
Change it to "/re/si". I think that should work for you.
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 01:09
how to set the fluent to show the 3D results in the xz plane? poiu FLUENT 8 January 30, 2013 06:51
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine kbhamidipa3 FLUENT 0 November 30, 2012 15:52
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
