September 1, 2014, 03:48 |
Simulating oscillating beam
Roni
Rep Power: 11 |
I'm trying to simulate an oscillating beam in a highly viscous fluid (I defined the solver on low Re). I created a UDF (simulating the beams first mode) and used it to create deformation of the walls. When I run the preview I get the right motion, but, when I run calculation I get wrong results. (im supposed to get symmetric vortices on both side of the beam but I get only one.
Is using deforming is the right choice? The motion supposed to be similar to vibration, I'm not Shure that this is what I get. I would really appreciate any help, I'm trying to find the problem for days. |
UDF for moving light beam | ppx | Fluent UDF and Scheme Programming | 0 | January 29, 2013 14:45 |
help debugging Beam deflection UDF | josik_1982 | Fluent UDF and Scheme Programming | 0 | December 19, 2010 17:36 |
comsol cantilever beam problem | bhu47 | COMSOL | 0 | June 30, 2008 14:59 |
FSI problem with topology of 3D beam via UDF | greg | FLUENT | 7 | July 17, 2006 05:32 |
Effect of fire on a steel beam | Amanda Fry | FLUENT | 1 | January 20, 2004 13:59 |
