Home > Forums > FLUENT
problem with heat transfer modeling!
Old   August 27, 2014, 10:29
Default problem with heat transfer modeling!
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hey
I have a comic problem with heat transfer modeling!
I'm modeling heat transfer in electronic components with using "source term" option!
But when the residuals converges the temperature of component is more than 1000K but temperature of surrounding air is same inlet temperature(about 300K)
What do you think?
Where do you think I am wrong?
Best regards,
Amin
amin.z is offline   Reply With Quote
Old   August 29, 2014, 03:25
amin.z's Avatar
Amin
Any idea friends?
I'm really confused! I'm checked very things but the problems exists yet!
The pressure and velocity contours are logical but temperature is irrational!
Also I Solved a simple problem (a triangle with heat flux BC) but a same problem happens! the pre. & velocity & temperature contours attached!
any reply could help me to solve the problem!
Best regards,
Amin
Old   August 29, 2014, 17:09
Syavash
syavash is on a distinguished road
Originally Posted by amin.z View Post
Any idea friends?
As you pointed out, this is a conjugate heat transfer (CHT) problem. make sure to select "coupled" option in thermal tab of the solid wall boundary condition.
Bests.
syavash is offline   Reply With Quote
Old   August 29, 2014, 23:40
amin.z's Avatar
Amin
Originally Posted by syavash View Post
Bests.
Tnx syavash for reply
It's ok! I'm checked the problem with coupled and I'm ensure about create shadow wall but the problem exist yet!
Best regards,
Amin
Old   August 30, 2014, 16:48
Syavash
Is your flow laminar or turbulent? it can really make difference!
Old   August 31, 2014, 09:12
amin.z's Avatar
Amin
In main case, there is a simple fan that rotating with angular velocity equal 2000 rpm and I'm using k-epsilon for turbulence model
Best regards,
Amin
Old   October 7, 2014, 09:22
madhu
TechAnalyst2012 is on a distinguished road
check the value u have given,,.. for example if u want to give 3000Watts and the volume of the heat source is 2metercube then , the value to be entered for heat source should be 3000/2 =1500 . it can also happen if u didnt give air flow or u have defined all walls as adiabatic
TechAnalyst2012 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Heat transfer modeling between two domains jeevan_yadav CFX 15 August 4, 2012 06:39
unsteady heat transfer model problem Beryl FLUENT 0 July 12, 2011 23:26
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
