August 29, 2014, 13:52 |
divergence detected in AMG solver X momentum
lavala srinivasarao
Rep Power: 11 |
after doing itreation suddenly got reversed flow and divergence detected in amg solver (this subsonic case). what should i do
somebody help me |
August 29, 2014, 14:51 |
Amin
Rep Power: 14 |
Usually this points could prevent the solution from divergence:
1. A good initializiation 2. Decreasing under relaxation factors and courant number 3. Selecting an appropriate discrete method And etc! Also sure that your BCs be ok! |
August 30, 2014, 13:59 |
amg solver
lavala srinivasarao
Rep Power: 11 |
and also i got one error non positive volume
August 30, 2014, 15:08 |
Amin
Rep Power: 14 |
it's occurred because volume of at least one cell is negative!
Usually grid generation is reason of this problem! Do you check your mesh when import its to fluent? If there are negative cells in first step it's better to repeat mesh generation again! and if you're solving a dynamic mesh i think you must update your mesh during the solution! |
August 31, 2014, 11:06 |
angle
lavala srinivasarao
Rep Power: 11 |
thank you sir,
i got it |
Error: Divergence detected in AMG solver | siri | FLUENT | 8 | March 12, 2018 17:08 |
Error: Divergence detected in AMG solver: pressure correction | wanna88 | FLUENT | 19 | April 6, 2016 02:57 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Divergence detected AMG solver error | Rub Nawaz Khalid | FLUENT | 2 | August 14, 2010 11:01 |
