Adding a specie sink in a wall
Old   September 3, 2014, 11:02
Default Adding a specie sink in a wall
Rui_27 is on a distinguished road
Hi everyone!
I using the VOF method to simulate water entering in a gas channel through a small pore in the bottom surface. The gas phase is dry air (0.21 O2 and 0.79 N2) and i would like to add a 02 sink in the bottom surface.
For now I consider a constant value for the sink, but in the future i will UDF to specify it.
I tried this:
First i separate the solid domain in two: Adapt -> boundary -> and I mark the cells adjacent to the bottom surface
Then i separate the marked cell from the entire domain: mesh ->separate -> cell -> and i select the marked cells
Then I add a source term (with a - signal because it is a sink): cell zone conditions -> solid:032 (the zone that i just separated) - > source terms -> O2 -> I a put the value 1e-6 kg/m-3/s-1
I did the simulation but the results are exactly the same as if i did not add any source. My source term is low and i already tried (much) larger values but the results does not changed.
Can anyone help me to with this?
Rui_27 is offline   Reply With Quote
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 08:43
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
UDF for a specie source in a specific wall Rui_27 Fluent UDF and Scheme Programming 0 September 1, 2014 13:54
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
