periodic boundary conditions in spanwise direction |
September 5, 2014, 11:12 |
omar
Rep Power: 16 |
Hi everybody
i want to simulate film cooling in a blade simplified model with three rows of cooling holes at leading edge (three holes at leading edge and two at pressure and suction side).This is only a portion of blade. Actually, I solved the case without problems, but now the aim is to simulate all the blade, for this I want to put periodic boundary conditions in spanwise direction. I dont know how to put it for this case. For example, at plenum domain i need to select two faces to periodicity in spanwise direction, but one of this faces is the flow inlet, then this face will have two boundary conditions and is not possible. Also i have doubts how to do it in fluid and blade domain. I use Gambit and Fluent. Can you help me? thanks in advance guys. I attach a picture of the model |
Translational Periodic Boundary Conditions | HeatTransferFan | CFX | 19 | December 12, 2016 11:15 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Parallel computation using periodic boundary conditions | AEMD | SU2 | 2 | March 26, 2014 23:41 |
Periodic boundary conditions for 2D pipe (water flow). | thess | FLUENT | 3 | May 31, 2012 13:38 |
Problem with periodic boundary conditions | jm_ngs | FLUENT | 7 | April 27, 2012 02:32 |
