FLUENT playing up? Or just an inaccurate solution?
Old   September 20, 2014, 05:32
Default FLUENT playing up? Or just an inaccurate solution?
Michael
mjkey is on a distinguished road
Hey guys,
I'm modelling a 3d passenger compartment and have recently gotten some weird results. I've attached two screen shots.
I mainly just use velocity pathlines and velocity contour plots to view my results. As you can see from the pathlines, the flow goes in this weird direction to the passenger side from both inlets and swirls around the compartment. This is very strange, as my other simulations they worked normal and went in a straight direction. Secondly, the scale says there should be red, orange etc. pathlines, which do not exist on the actual pathlines (all blue). So not only are the pathlines all flying in the wrong direction, they don't show their true velocities : [ To verify my pathlines weird colours problem, i checked my contour plots (as attached). The range and all are the same as with the pathline and it shows the red, orange, yellow section at the incoming duct (which is correct).
I'm just confused as to whether my solution is completely inaccurate (the weird flow direction, all blue) or is FLUENT playing up?
Anyone experienced this before? Any comments?
Cheers!
mjkey is offline   Reply With Quote
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
Accuracy in Boundary Layer solution in Fluent rameshbhoraniya FLUENT 3 September 7, 2013 02:26
define a water-salt solution in fluent mnmnjk FLUENT 0 June 20, 2013 16:50
mesh size interaction with fluent solution?? Prince Samson FLUENT 1 January 20, 2006 05:35
