divergence in termperature when thermal conductivity is zero
Old   September 23, 2014, 04:01
Default divergence in termperature when thermal conductivity is zero
Jacky
bharat.cmeri is on a distinguished road
Hi all,
I tried to remove thermal diffusion term by giving zero value for thermal conducitivity for the working fluid but fluent returned divergence in n temperature.... Can some one suggest how to do this.
Thanks & Regards,
Bharat
bharat.cmeri is offline   Reply With Quote
Old   September 23, 2014, 04:12
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I suggest to set a value "very small"; the effect should be the same. Zero values in fluent are not good as there can be some division by zero..
ghost82 is offline   Reply With Quote
Old   September 23, 2014, 05:35
Jacky
Hi ,
Thanks for your reply. I also figured same thing. Can you answer me one more thing ?
I am presently modeling an enthalpy equation for mixture model for modeling boiling in porous media. In this eqn the convective flux is different from the one used by de3fault. SO I wrote a define-uds-flux macro for returning the desired value to the solver. Now when I give very small value to its diffusion coefficient, aftyer some iterations the solver gives divergence error.
However this was not so in the case of energy equation.....
Anmy feedback or sugggestion would be highly appreciated.
Thanks & Regards,
Bharat
PS: I have followed fluent's udf manual for writing define-uds-flux macro.
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 10:38
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 17:26
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
