DPM-SteadyFlow-About Stop/Stard Time Properties and Particle Time Step Size |
October 8, 2014, 11:33 |
souria
Rep Power: 13 |
Hey everyone,
What is exact meaning of stop time in the set injection properties in the fluent under define injection ? I'm simulating sediment transport (in river) for a STEADY FLOW. In case, I choose "Unsteady Particle Tracking" , these parameters refer to what step ? What time ? Start time, Stop Time The Particle Time Step size Number of time Steps Max. Number of steps Step Length Are these parameters depending on the time of calculation ? or on the number of the iterations ? Thanks for your help Souria |
October 8, 2014, 23:43 |
Ghazlani M. Ali
Rep Power: 28 |
Hi souria,
When the DPM (discrete phase model) is activated, The calculation related to your particles are not solved in the same time as your gasous domain. the two calculation are done separately. Fluent solves your flow for a certain given iterations (that you provided), then makes a pause to use calculated properties in the DPM calculation. Therefor, you can solve your gaseous domain in a steady state fashion, and the DPM in a transient fashion. You have to understand that the two calculation are done separately. and since the dpm is in a transient fashion, obviously you have to set a time step, start and stop time. I hope I was clear |
October 9, 2014, 03:36 |
souria
Rep Power: 13 |
Thans for your answer, If I'd really get it, you mean there's no relationship between the number of iterations (Im in steady flow, so the calculation is just gouverned by itérations and no time step...) and the Time step that we choose to solve the DPM.
particle time step size, number of time steps in DPMPM | lili | FLUENT | 25 | August 25, 2017 08:36 |
cyclone separator particle tracking prob.. | sakurabogoda | CFX | 33 | May 29, 2013 06:36 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
URGENT - DPM Particle Properties | Sandilya Garimella | FLUENT | 1 | March 5, 2008 14:19 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
