Is it possible to use Unsteady DPM with Steady flow case ? |
October 9, 2014, 11:48 |
souria
Rep Power: 13 |
Why can't I use Unsteady DPM with Steady flow case when we don't enable the Interaction parameters ? I try to do it and I get this message : "Attention, for steady flow cases, unsteady particle are available only, if interaction with continuous phase is enabled" I'm using Fluent 15, Last edited by souria; October 10, 2014 at 05:15. |
Unsteady DPM with steady solver | elobb | FLUENT | 4 | December 16, 2021 03:54 |
unsteady flow, when do you use steady when do you switch to transient | jpc | Main CFD Forum | 19 | November 17, 2014 11:17 |
unsteady DPM and steady flow | Mohsin | FLUENT | 6 | October 9, 2014 05:30 |
Numerical error or case error? Flow in a 3D pipe | fsalvucci | OpenFOAM | 40 | January 30, 2013 07:10 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 01:12 |
