Significant change in results with changing either mesh size or time step size.
Like Tree2Likes
  • 1 Post By CeesH
  • 1 Post By CeesH
Old   October 19, 2014, 05:42
Default Significant change in results with changing either mesh size or time step size.
Ali
nettpanic is on a distinguished road
Dear All,
I need your help. I am trying to simulate the adsorption process of CO2 in a tank filled with activated carbon (adsorbent). This is a transient case. I have successfully simulated this process, but the problem is with changing the mesh size results change significantly, similarly the same thing happens when I change the time step size. Please need your suggestions to to get out of this situation. Axisymmetric geometric model of the storage system is attached.
Regards,
nettpanic is offline   Reply With Quote
Old   October 21, 2014, 02:01
Cees Haringa
CeesH is on a distinguished road
My suggestion: decrease your mesh and timestep size to a size where they do not significantly influence the solution. Clearly, your results are not grid/stepsize independent. What else do you think you could do about that?
nettpanic likes this.
CeesH is offline   Reply With Quote
Old   October 21, 2014, 02:12
Ali
Dear Ceesh
Thanks for your valuable suggestion. I have tried many different settings including grid refinement. Initially My mesh comprises of 12240 cells. I have refined my mesh till 92000. But facing same problem. I have tried different pressure-velocity coupling schemes, and also change the spatial discretization to second order upwind. But of no use. I haven't tried coarse mesh below 12240 cells.
Old   October 21, 2014, 03:17
Cees Haringa
Some questions: Is the case 2 or 3-D?
Do your residuals converge (and do other monitors you may be using converge) during a simulation?
If you plot your results versus mesh density or timestep size, do you see any trend?
Old   October 21, 2014, 13:12
Ali
Dear Ceesh
Here are my observations:
1) It is a 2D case
2) Residuals are converging well
3) I am monitoring Temperature at different points within the storage system, once I plot these temperature agains mesh density and time step size follwoing trend has been observed;
a) Keeping time step size constant (t=3sec), increasing the mesh density from 12240 cells to 91000 cells, temperature at the center point of the storage tank decreases from 350K to 318K.
b) Keeping the mesh density constant (12240 cells) increasing the time step size decreases the temperature at above mentioned location from 350K to 325K.
Old   October 24, 2014, 02:37
Cees Haringa
What did you base the timestep size on? It seems like it may be too high, causing the problems. A converging solution doesn't mean a mesh independent solution of course, so maybe you simply need to reduce the time and mesh size until you do find a solution which is independent of those parameters..
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
