Periodically occuring reverse flow after residuals have converged |
October 29, 2014, 09:47 |
zack
Rep Power: 11 |
Greetings CFD users
I have found an interesting problem on a tutorial on electronics cooling by forced convection https://confluence.cornell.edu/displ...lectronics+Box As mentioned I have used velocity inlet and pressure outlet. The graph of residuals for momentum and continuity will become a straight zero slope line.So naturally people will assume convergence and stop the iterations. However after every 100 or so iterations after that,there will be continous messages of reversed flow at pressure outlet for the next 20 iterations After this the number of reverse flow iterations steps will increase to the point that all steps show reverse flow. and finally divergence also occurs. This is true even if velocity at inlet is increased substansially. Thus no matter how many times this process is done there will be this same pattern repeated. In such a case can I trust the results have converged?If not what things do I need to change? Also being a physics student could someone tell me why this "repeating"reverse flow occurs ? Thank you |
October 29, 2014, 16:59 |
zack
Rep Power: 11 |
Why is no one answering is the problem not well explained?
convection dominated, convergence fluent, convergence issues, reverse flow |
Display Modes | |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Reverse flow warning and solution divergence | SH_P | FLUENT | 0 | May 27, 2012 15:26 |
Reverse Flow Problem. (Hull with a Bulbous Bow )Towing Tank simulation. | Nyarla | Siemens | 2 | March 13, 2012 19:04 |
flow field residuals into posdat? | nicola | Siemens | 0 | February 9, 2007 10:54 |
