November 2, 2014, 12:01 |
k-e values
Manu Poolakkal
Rep Power: 11 |
need the values of "turbulent kinetic energy" and "turbulent dissipation rate" of ammonia vapor and liquid in order to run calculations in fluent. somebody please help me to get the same.
November 2, 2014, 19:31 |
Lucky
Rep Power: 65 |
Those values are extremely problem dependent. One of the most convenient ways is to compute them from turbulence intensity and length scale. Having gone through literature certainly helps.
Do you need k-e at inlets or as initial conditions? A popular guess is to use smooth pipe correlations. http://www.cfd-online.com/Wiki/Turbulence_intensity You can fudge the initial conditions and still eventually get a result. But you can't do that at inlets. |
November 3, 2014, 00:30 |
Manu Poolakkal
Rep Power: 11 |
thank you sir.i calculated it from turbulent intensity and length scale.
Display Modes | |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
Retrieving boundary patch values adjacent to a given cell | brooksmoses | OpenFOAM Post-Processing | 2 | December 8, 2008 10:00 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
node based or cell centered Ts values | acboge | FLUENT | 0 | February 6, 2004 06:41 |
