November 12, 2014, 02:53 |
Convergent-divergent nozzle flow
shikha
Rep Power: 12 |
Hello Friends,
I am trying a nozzle flow. The following settings have been used here: Energy equation- on model-inviscid courant number- 0.1 inlet- velocity inlet outlet- pressure outlet boundary- symmetry hybrid initialization of two zones (subsonic and supersonic) The nozzle sketch is uploaded for your convenience. However,while running the simulation I am getting following error with every iteration: time step reduced in 162 cells due to excessive temperature change temperature limited to 1.000000e+00 in 145 cells on zone 10 temperature limited to 5.000000e+03 in 217 cells on zone 10 temperature limited to 1.000000e+00 in 2 cells on zone 11 temperature limited to 5.000000e+03 in 8 cells on zone 11 If anyone can help or suggest me that how to deal with it. I shall be very greatful to him/her. Thanks in advance. |
November 12, 2014, 03:41 |
hana
Rep Power: 11 |
I thought temperature limit error will be disappear after more iteration
November 12, 2014, 04:12 |
shikha
Rep Power: 12 |
Thank you for your quick reply.
But, upto 2000 iteration it was showing like this. However,I will try then with more iteration as per your suggestion. |
November 12, 2014, 04:28 |
Xiaosheng Chen
If the error message is still there after some iterations, it may be better to check the inlet and outlet boundary conditions by 1D analysis to make sure they are reasonable.
November 13, 2014, 00:57 |
shikha
Rep Power: 12 |
Thank you all for the reply...I will try the suggestions and will update you.
November 14, 2014, 05:53 |
shikha
Rep Power: 12 |
Hello friends,
I could able to run an error free simulation but a new problem arised...the continuity equation is not converging and hence I am not gettong converged solution. If anyone can help me with bthis problem!! |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
inlet and outlet for convergent nozzle | josh99 | FLUENT | 1 | December 25, 2011 13:24 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
Compressible de Laval Nozzle Flow | rw511 | CFX | 3 | May 22, 2011 19:48 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
