Home > Forums > FLUENT
what does the continuty residual means??????
Old   November 12, 2014, 19:01
Default what does the continuty residual means??????
jonior is on a distinguished road
hi,
in my simulation calculation all the residuals are converging well but the continuity is taken tooooooooo much iterations ???????
can any one tell me to which it refers(what does it mean)
and how can i improve its behavior to minimize the number of iterations
jonior is offline   Reply With Quote
Old   November 13, 2014, 05:09
pakk will become famous soon enough
For this, the best place to start looking is the help.
pakk is offline   Reply With Quote
Old   November 13, 2014, 13:39
B_Kia
HyperNova is on a distinguished road
Originally Posted by jonior View Post
hi,
it depends , first check your boundry conditions , uncorrect boundry condition may result to this , what is it exactly you are modelling ? notice that in fluent continuitu is not a solver equation , it is checker equation , sometimes it is not important to converge the continuity !
HyperNova is offline   Reply With Quote
Old   November 13, 2014, 19:22
Lucky Tran
LuckyTran will become famous soon enough
Have you been resetting the residual statistics repeatedly?
The continuity residual is scaled based on the worst mass imbalance encountered in the first 5 iterations. If you initial guess or initial conditions are "good" the worst residual encountered in the first iterations will not be very high. This may give the impression that the continuity residual is not "converging" even though the solution is accurately computed. If you initialize the simulation with the solution, your continuity residual will be stuck at 1. Can this explain your situation?
Old   November 14, 2014, 15:25
dera lucky,
thanks so much for your help yes this explaining my simulation
i understant from your reply that my simulation is very good estimated?
despite all other residuals are converging until reach E-4, the continuty is almost constant at 1 and nearly E-1
did i understand you right
Old   November 14, 2014, 21:43
Lucky Tran
No. It is sufficient though not necessarily true and it is unlikely to be the case. I merely proposed this as an explanation if and you would know if you have been repeatedly resetting the residual statistics or if the initial guess is incredibly accurate. By the way, it would have to be accurate over the whole domain. Resetting the residuals is fairly easy to do by accident.
Thread Tools
Trackbacks are On
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
