November 14, 2014, 08:09 |
How/When to run DPM in Steady Flow ?
souria
I'm looking to track particle (using DPM) in steady flow. So, I run first the fluid phase till convergence (the convergence is obtained after 3000 iterations). After that, I injected particles to the fluid but I don't know how many iterations should I impose !! Does the DPM tracking depends on the number of iterations ?? Since my fluid phase is converged is it necessary to run more iterations ?? I'm really confused , thanks for your help |
November 14, 2014, 21:02 |
Lucky
Rep Power: 65 |
If this is a steady state simulation, run the DPM after your flow solution is converged. You don't need to iterate the flow anymore. There are some settings in DPM menu, but you can leave those as defaults. There are some sub iterations in the DPM when the particles are injected to track their trajectory.
November 17, 2014, 03:38 |
souria
LuckyTran, Yes I'm runing a steady state, and I want to run DPM after my flow is converged without iterating the flow again ..
when you talk about "some settings in DPM menu" what did you talk about ?? I checked all DPM box but I didn't find something let me run the DPM !! Thanks for your help |
November 17, 2014, 05:30 |
souria
Please, is any there here to help me.
So, I try to simulate sediment transport in river. This is my condition : Steady flow (stationnary flow) with Uncoupled approach (one way coupling) and of corse the DPM is unsteady. I search a way to run the DPM without running again the flow (Since the flow is converged so i think its not useful to run the flow again when I run the DPM), but in DPM setting Box I don't find a way to do this ?? If you have answer for my question it will be great Thanks all |
September 28, 2018, 21:48 |
Melisa Cardona
Rep Power: 8 |
In the solution controls window choose Equations and deselected flow. Then run again the simulation. It will calculate only the DPM without modifying the flow
January 22, 2020, 10:45 |
DPM in steady flow
hossein
Dear all
I'm looking for run a dpm injection in steady state flow. In order to first I run steady flow to converged. After that I active the dpm but I'm realy confused how should do that? Please help me. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
unsteady DPM and steady flow | Mohsin | FLUENT | 6 | October 9, 2014 05:30 |
initialize flow field with steady state solution | holg | FLUENT | 0 | July 13, 2009 17:10 |
Unable to achieve a steady flow | lost.identity | Main CFD Forum | 1 | April 29, 2009 10:22 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
