bubble separator device
Old   November 16, 2014, 12:15
Default bubble separator device
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey friends!
I need your suggestions!
I'm working on a bubble separator System!
in this device, air and jet of water enter to a tube, then due to buoyancy force, air bubbles separate from water!
based on your experience, which multiphase model do you suggest for my problem!? VoF or mixture or...?
amin.z is offline   Reply With Quote
Old   November 16, 2014, 12:24
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I would suggest mixture/eulerian if air > 10% volume fraction (mixture less computationally expensive than eulerian, and maybe more stable, but maybe less accurate), vof if you want to study water/air interfaces.
Discrete phase model if air <= 10%.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   November 16, 2014, 12:53
amin.z's Avatar
Amin
Tnx my dear friend!
I think volume fraction of air is more than 20%
in my model, air bubbles are floating in the water and due to buoyancy force, they move upward! so both of fluid have interaction
therefore what is your suggestion!?
Old   November 16, 2014, 12:54
ghost82's Avatar
Rick
I would go for Eulerian. If stability will be a problem switch to mixture.
Old   November 16, 2014, 12:57
amin.z's Avatar
Amin
thank you so much!
2D bubble rising through a column of water vof64 Fluent Multiphase 0 August 19, 2014 23:42
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 08:41
[ANSYS Meshing] Bubble modelling to simulate shape oscillations akash ANSYS Meshing & Geometry 5 February 1, 2013 01:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
